Up to 20% off select tools
Disassembling Sony Ericsson W580i Back Cover
Views: 9.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
124
All Time:
9,891
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the back cover and access the motherboard.
    1. Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 1 of 3 Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 2 of 3 Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 3 of 3
      • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
      • The panel will slide down about 2mm.
      • Lift the panel away from the phone.
      Ask FixBot
    2. Disassembling Sony Ericsson W580i Back Cover: step 2, image 1 of 1
      • Lift the battery out from the bottom edge.
      Ask FixBot
    1. Disassembling Sony Ericsson W580i Back Cover, Back Cover: step 3, image 1 of 1
      • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
      • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
      • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
      Ask FixBot
    2. Disassembling Sony Ericsson W580i Back Cover: step 4, image 1 of 3 Disassembling Sony Ericsson W580i Back Cover: step 4, image 2 of 3 Disassembling Sony Ericsson W580i Back Cover: step 4, image 3 of 3
      • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
      • Pull the back cover away from the phone.
      • Remove the power button if it has not already come off.
      Ask FixBot
4 other people completed this guide.
Author
with
Cherie
220 Reputation
2 Guides authored
Cal Poly, Team 5-31, Amido Fall 2011 Member of Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 124
All Time: 9,891
