Up to 20% off select tools
Disassembling Sony Ericsson T68i
Views: 7.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
98
All Time:
7,116
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide will help you to disassemble your Sony Ericsson T68i.
    1. Disassembling Sony Ericsson T68i, Disassembling Sony Ericsson T68i: step 1, image 1 of 2 Disassembling Sony Ericsson T68i, Disassembling Sony Ericsson T68i: step 1, image 2 of 2
      • Remove the battery from the back.
      Ask FixBot
    2. Disassembling Sony Ericsson T68i: step 2, image 1 of 3 Disassembling Sony Ericsson T68i: step 2, image 2 of 3 Disassembling Sony Ericsson T68i: step 2, image 3 of 3
      • Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips.
      • When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
      Ask FixBot
    3. Disassembling Sony Ericsson T68i: step 3, image 1 of 3 Disassembling Sony Ericsson T68i: step 3, image 2 of 3 Disassembling Sony Ericsson T68i: step 3, image 3 of 3
      • Unscrew all four Torx T6 screws.
      • Keep in a safe place.
      Ask FixBot
    4. Disassembling Sony Ericsson T68i: step 4, image 1 of 3 Disassembling Sony Ericsson T68i: step 4, image 2 of 3 Disassembling Sony Ericsson T68i: step 4, image 3 of 3
      • After removing the screws, the two halves will separate. If not, then pry them gently apart.
      Ask FixBot
    5. Disassembling Sony Ericsson T68i: step 5, image 1 of 2 Disassembling Sony Ericsson T68i: step 5, image 2 of 2
      • Pull off the keypad.
      Ask FixBot
    6. Disassembling Sony Ericsson T68i: step 6, image 1 of 3 Disassembling Sony Ericsson T68i: step 6, image 2 of 3 Disassembling Sony Ericsson T68i: step 6, image 3 of 3
      • Gently pull off the infra red window and the vibra motor.
      Ask FixBot
    7. Disassembling Sony Ericsson T68i: step 7, image 1 of 3 Disassembling Sony Ericsson T68i: step 7, image 2 of 3 Disassembling Sony Ericsson T68i: step 7, image 3 of 3
      • Remove the circuit board and screen from the device.
      • Use your T6 to remove the 4 screws holding the cover on.
      Ask FixBot
    8. Disassembling Sony Ericsson T68i: step 8, image 1 of 3 Disassembling Sony Ericsson T68i: step 8, image 2 of 3 Disassembling Sony Ericsson T68i: step 8, image 3 of 3
      • Remove the board and screen.
      Ask FixBot
    9. Disassembling Sony Ericsson T68i: step 9, image 1 of 2 Disassembling Sony Ericsson T68i: step 9, image 2 of 2
      • Lever out the microphone using a small screwdriver or any similar tool.
      Ask FixBot
    10. Disassembling Sony Ericsson T68i: step 10, image 1 of 3 Disassembling Sony Ericsson T68i: step 10, image 2 of 3 Disassembling Sony Ericsson T68i: step 10, image 3 of 3
      • Carefully remove the plastic clips holding the screen on the board.
      Ask FixBot
    11. Disassembling Sony Ericsson T68i: step 11, image 1 of 3 Disassembling Sony Ericsson T68i: step 11, image 2 of 3 Disassembling Sony Ericsson T68i: step 11, image 3 of 3
      • Remove the speaker located in the screen housing just above the screen.
      • Gently pry it out with a small screwdriver or similar tool.
      Ask FixBot
    12. Disassembling Sony Ericsson T68i: step 12, image 1 of 3 Disassembling Sony Ericsson T68i: step 12, image 2 of 3 Disassembling Sony Ericsson T68i: step 12, image 3 of 3
      • Remove the plate from the circuit board protecting the more delicate processing parts.
      Ask FixBot
    13. Disassembling Sony Ericsson T68i: step 13, image 1 of 1
      • Congratulations, you have successfully disassembled your Sony Ericsson T68i!
      Ask FixBot
6 other people completed this guide.
Author
with
Tim Dascomb
174 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 98
All Time: 7,116
