Disassembling Sony Cyber-Shot DSC-W330 Outer Casing
  1. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: step 1, image 1 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: step 1, image 2 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing, Outer Casing: step 1, image 3 of 3
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
    Ask FixBot
  2. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 2, image 1 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 2, image 2 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 2, image 3 of 3
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
    Ask FixBot
  3. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 3, image 1 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 3, image 2 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 3, image 3 of 3
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
    Ask FixBot
  4. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 4, image 1 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 4, image 2 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 4, image 3 of 3
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
    Ask FixBot
  5. Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 5, image 1 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 5, image 2 of 3 Disassembling Sony Cyber-Shot DSC-W330 Outer Casing: step 5, image 3 of 3
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
    Ask FixBot
2 other people completed this guide.
Hunter Stewart
426 Reputation
3 Guides authored
Clemson, Team 13-4, Benson Fall 2013 Member of Clemson, Team 13-4, Benson Fall 2013
CLEM-BENSON-F13S13G4
3 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 54
All Time: 1,501
