Disassembling Sony Clie PEG-NR70 The Case
  1. Disassembling Sony Clie PEG-NR70 The Case, The Case: step 1, image 1 of 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
    Ask FixBot
  2. Disassembling Sony Clie PEG-NR70 The Case: step 2, image 1 of 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
    Ask FixBot
  3. Disassembling Sony Clie PEG-NR70 The Case: step 3, image 1 of 2 Disassembling Sony Clie PEG-NR70 The Case: step 3, image 2 of 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
    Ask FixBot
Daniel Soski
63 Reputation
6 Guides authored
Cal Poly, Team 14-11, Maness Spring 2013 Member of Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,085
