Disassembling Sony CDX-GT565UP Front Panel/Faceplate
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
73
All Time:
162
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Disassembling Sony CDX-GT565UP Front Panel/Faceplate, Remove back plate: step 1, image 1 of 1
      • Remove 4 Philips?/JIS? cross-head screws
      • Carefully unsnap the 6 to 10 (i did not count them) edge snaps around the rim of the back cover. See photo for example locations along top edge.
      • Keep track of the front panel eject button and spring as you remove the back cover. They are loose and can fall out. The button shape is indexed, so it will only fit back in one rotational orientation.
      Ask FixBot
    2. Disassembling Sony CDX-GT565UP Front Panel/Faceplate, Circuit board rear access: step 2, image 1 of 1
      • Access to the rear (foil, solder joint side) of the circuit board is complete, if this is all that is needed.
      • Note that the board is loose inside the front plastic frame, held in only by friction and the control knob.
      Ask FixBot
    3. Disassembling Sony CDX-GT565UP Front Panel/Faceplate, Remove circuit board from front plastic: step 3, image 1 of 1
      • Pull control (volume/settings) knob straight off (perpendicular to axis of rotation)
      • Open USB cover and push on USB port—if necessary—to ease PCB out of front faceplate plastic
      Ask FixBot
Disassembly is complete. To reassemble your device, follow these instructions in reverse order.
Sonic Purity
277 Reputation
2 Guides authored
1 Guide Comment
Gracias, sirvió la explicación de sacar la perilla de volumen
Manuel Rosales - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 73
All Time: 162
