Disassembling Siemens A56 Motherboard from Keypad Interface
  1. Disassembling Siemens A56 Motherboard from Keypad Interface, Battery: step 1, image 1 of 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
    Ask FixBot
  2. Disassembling Siemens A56 Motherboard from Keypad Interface: step 2, image 1 of 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
    Ask FixBot
  3. Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: step 3, image 1 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: step 3, image 2 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Front Plate: step 3, image 3 of 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
    Ask FixBot
  4. Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: step 4, image 1 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: step 4, image 2 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Back Plastic Cover: step 4, image 3 of 3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
    Ask FixBot
  5. Disassembling Siemens A56 Motherboard from Keypad Interface: step 5, image 1 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface: step 5, image 2 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface: step 5, image 3 of 3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
    Ask FixBot
  6. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: step 6, image 1 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: step 6, image 2 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard Metal Frame: step 6, image 3 of 3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
    Ask FixBot
  7. Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: step 7, image 1 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: step 7, image 2 of 3 Disassembling Siemens A56 Motherboard from Keypad Interface, Motherboard from Keypad Interface: step 7, image 3 of 3
    • Insert the fine-tipped spudger in between the motherboard and the keypad interface.
    • Gently work the spudger across the length of the motherboard.
    • An adhesive exists between the motherboard and the keypad interface.
    • Once loosened, the motherboard should easily separate from the keypad interface.
    Ask FixBot
Joseph Casey
414 Reputation
4 Guides authored
Clemson, Team 6-6, Benson Spring 2014 Member of Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Members
27 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 556
