Disassembling Sanyo VPC-T850 Outer Casing
    1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: step 1, image 1 of 1
      • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
      • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
      • In the compartment, move the small notch and push down on the battery to remove it.
      • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
      Ask FixBot
    2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 3 of 3
      • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
      Ask FixBot
    3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 3 of 3
      • Using the spudger, gently pry the rear panel away from the left side.
      • Be careful not to damage the three green cables as you remove the rear panel of the camera.
      Ask FixBot
    4. Disassembling Sanyo VPC-T850 Outer Casing: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
      • Do not put any excessive force on the green wires.
      Ask FixBot
    5. Disassembling Sanyo VPC-T850 Outer Casing: step 5, image 1 of 1
      • Separate the rear panel from the rest of the camera.
      Ask FixBot
    6. Disassembling Sanyo VPC-T850 Outer Casing: step 6, image 1 of 2 Disassembling Sanyo VPC-T850 Outer Casing: step 6, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
      • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
      Ask FixBot
    7. Disassembling Sanyo VPC-T850 Outer Casing: step 7, image 1 of 2 Disassembling Sanyo VPC-T850 Outer Casing: step 7, image 2 of 2
      • Carefully pull off the side covers wrapped around the camera.
      Ask FixBot
    8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 3 of 3
      • Using the spudger, gently lift off the front cover of the camera.
      • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
      Ask FixBot
Jonathan Yau
26 Reputation
4 Guides authored
Cal Poly, Team 27-95, Amido Spring 2010 Member of Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,596
