Disassembling Samsung Gravity SGH-T459 Rear Case
    1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Back Cover: step 1, image 1 of 1
      • Press and hold the End key to power down the cell phone.
      • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
      Ask FixBot
    1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Battery: step 2, image 1 of 1
      • Gently lift up and remove battery with your fingers in the direction of the arrows.
      Ask FixBot
    1. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 1 of 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 2 of 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 3 of 3
      • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
      • Slide the phone open.
      • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
      • Gently lift and remove the rear case from the cell phone.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 677
