Disassembling Samsung Gear 2 Front half and Back half
    1. Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: step 1, image 1 of 2 Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: step 1, image 2 of 2
      • Before disassembling your Gear, be sure it is powered off.
      • To remove each strap, locate the metal latches on both sides of the back of the Gear.
      • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
      Ask FixBot
    2. Disassembling Samsung Gear 2 Front half and Back half: step 2, image 1 of 1
      • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
      Ask FixBot
    3. Disassembling Samsung Gear 2 Front half and Back half: step 3, image 1 of 3 Disassembling Samsung Gear 2 Front half and Back half: step 3, image 2 of 3 Disassembling Samsung Gear 2 Front half and Back half: step 3, image 3 of 3
      • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
      • Pry the device open from the other side also if it does not fully disassemble from one side.
      Ask FixBot
4 other people completed this guide.
Jonathan Molina
1,018 Reputation
2 Guides authored
Cal Poly, Team 13-27, Maness Spring 2014 Member of Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 107
All Time: 3,710
