Disassembling Samsung Galaxy S Blaze Whole Device
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
93
All Time:
1,367
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide allows users of the Samsung Galaxy S Blaze to take the phone apart. You will need to be careful with the screws that are inside the device, the screws will strip easily. To properly disassemble the phone you will need a Phillips Head screw driver size 00 and a flat wedge opening device.
Tools
    1. Disassembling Samsung Galaxy S Blaze Whole Device, Device: step 1, image 1 of 1
      • Remove the back plate.
      Ask FixBot
    2. Disassembling Samsung Galaxy S Blaze Whole Device: step 2, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    3. Disassembling Samsung Galaxy S Blaze Whole Device: step 3, image 1 of 2 Disassembling Samsung Galaxy S Blaze Whole Device: step 3, image 2 of 2
      • Use a Phillips head screwdriver size 00.
      • Remove the 4mm screws from the frame.
      • The eight screws are all the same size.
      Ask FixBot
    4. Disassembling Samsung Galaxy S Blaze Whole Device: step 4, image 1 of 1
      • Remove the frame from the phone by using the blue plastic opening tool.
      • Work around the phone with the tool until the frame is off.
      • You may need to use a bit of force to pry off the frame.
      Ask FixBot
    5. Disassembling Samsung Galaxy S Blaze Whole Device: step 5, image 1 of 1
      • The volume rocker is attached to the frame by two plastic prongs.
      • Unhook the prongs from the frame and remove the volume rocker.
      Ask FixBot
    6. Disassembling Samsung Galaxy S Blaze Whole Device: step 6, image 1 of 1
      • The SD card slot is held in place by a small tab.
      • Unhook the tab of the SD card slot, from the frame of the phone.
      Ask FixBot
    7. Disassembling Samsung Galaxy S Blaze Whole Device: step 7, image 1 of 1
      • The power button is attached to the phone with two prongs.
      • Unhook the prongs of the power button from the frame of the phone.
      Ask FixBot
    8. Disassembling Samsung Galaxy S Blaze Whole Device: step 8, image 1 of 3 Disassembling Samsung Galaxy S Blaze Whole Device: step 8, image 2 of 3 Disassembling Samsung Galaxy S Blaze Whole Device: step 8, image 3 of 3
      • 4 ribbon cable connectors hold the motherboard to the phone.
      • The first 3 are all on one side.
      • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
      Ask FixBot
    9. Disassembling Samsung Galaxy S Blaze Whole Device: step 9, image 1 of 1
      • Flip the motherboard over to access the last ribbon cable connector.
      • Unlatch the final ribbon cable connector from the phone.
      • Remove the motherboard from the phone.
      Ask FixBot
    10. Disassembling Samsung Galaxy S Blaze Whole Device: step 10, image 1 of 1
      • All of the parts are seen here.
      Ask FixBot
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2 other people completed this guide.
Jake Best
264 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 93
All Time: 1,367
