Disassembling SKIL 4235 Jigsaw Base plate
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
118
All Time:
4,122
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide is to remove the base plate. This will allow you to access the rest of your saw and disassemble it properly.
Tools
    1. Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: step 1, image 1 of 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: step 1, image 2 of 3 Disassembling SKIL 4235 Jigsaw Base plate, Disassembling SKIL 4235 Jigsaw Base plate: step 1, image 3 of 3
      • Orient your saw so that the blade is pointing in the opposite direction of your body. Ensure that the screws circled are visible and pointing skyward. This will be the standard position of the Jigsaw for the duration of this guide.
      Ask FixBot
    2. Disassembling SKIL 4235 Jigsaw Base plate: step 2, image 1 of 1
      • Using two hands grip both side of the saw and lay on side.
      Ask FixBot
    3. Disassembling SKIL 4235 Jigsaw Base plate: step 3, image 1 of 1
      • With bottom of the base plate visible, identify one M4 screw circled in red and remove with Phillips screwdriver (some models have flathead screw, as pictured, and require flathead screwdriver).
      Ask FixBot
    4. Disassembling SKIL 4235 Jigsaw Base plate: step 4, image 1 of 1
      • After removing M4 screw, remove the base plate and place to the side. Don't forget to replace the M4 screw near the base plate during re-installation.
      Ask FixBot
Adam Cardoso
357 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 118
All Time: 4,122
