Up to 20% off select tools
Disassembling REL T5 Transformer
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
98
All Time:
288
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Disassembling REL T5 Transformer, Remove screws: step 1, image 1 of 3 Disassembling REL T5 Transformer, Remove screws: step 1, image 2 of 3 Disassembling REL T5 Transformer, Remove screws: step 1, image 3 of 3
      • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
      • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
      • Make sure to support the plate amp by gripping the heat sink.
      • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
      • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
      Ask FixBot
    2. Disassembling REL T5 Transformer, Disconnect the driver: step 2, image 1 of 2 Disassembling REL T5 Transformer, Disconnect the driver: step 2, image 2 of 2
      • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
      Ask FixBot
    3. Disassembling REL T5 Transformer, Remove plate amp: step 3, image 1 of 1
      • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
      • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
      Ask FixBot
    1. Disassembling REL T5 Transformer, Snip all connecting trywraps: step 4, image 1 of 2 Disassembling REL T5 Transformer, Snip all connecting trywraps: step 4, image 2 of 2
      • Snip all tywraps, such that all cables can be manipulated freely.
      Ask FixBot
    2. Disassembling REL T5 Transformer, Disconnect connectors: step 5, image 1 of 2 Disassembling REL T5 Transformer, Disconnect connectors: step 5, image 2 of 2
      • Disconnect all connectors that tie to the transformer
      • Make sure that all leads can be manipulated freely.
      Ask FixBot
    3. Disassembling REL T5 Transformer, Loosen screws: step 6, image 1 of 2 Disassembling REL T5 Transformer, Loosen screws: step 6, image 2 of 2
      • Start loosening the screws on the back using the m3 hex tool
      • Don't remove them fully, yet though.
      Ask FixBot
    4. Disassembling REL T5 Transformer, Remove screws: step 7, image 1 of 2 Disassembling REL T5 Transformer, Remove screws: step 7, image 2 of 2
      • Turn the amp on it's back.
      • Remove the nuts from the screws that where loosened on the back.
      • Remove the philips screws using a #2.
      Ask FixBot
    5. Disassembling REL T5 Transformer, Loosen dampening rubber: step 8, image 1 of 1
      • Loosen the dampening rubber by running a Halberd Spudger underneath it.
      • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
      Ask FixBot
    6. Disassembling REL T5 Transformer, Remove transformer: step 9, image 1 of 2 Disassembling REL T5 Transformer, Remove transformer: step 9, image 2 of 2
      • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
      Ask FixBot
Author
with
Jasper van Zuijlen
1,200 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 98
All Time: 288
