Up to 20% off select tools
Disassembling REL T5 Main Amplifier
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
79
All Time:
351
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 hours
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Disassembling REL T5 Main Amplifier, Remove screws: step 1, image 1 of 3 Disassembling REL T5 Main Amplifier, Remove screws: step 1, image 2 of 3 Disassembling REL T5 Main Amplifier, Remove screws: step 1, image 3 of 3
      • Place the subwoofer on it legs to protect the driver. Be careful not to touch the driver/speaker on the bottom when you handle the case.
      • Using the 3mm hex tool, remove only the outer rim of screws, starting from the bottom.
      • Make sure to support the plate amp by gripping the heat sink.
      • Remove the top screws. Be aware: the heavy transformer is located at the top. Removing the top screws will probably make the plate amp tilt out of the case.
      • Using the heatsink, carefully lift the plate amp out of the case. Again: it's heavier than you might expect!
      Ask FixBot
    2. Disassembling REL T5 Main Amplifier, Disconnect the driver: step 2, image 1 of 2 Disassembling REL T5 Main Amplifier, Disconnect the driver: step 2, image 2 of 2
      • The plate amp is still connected to the driver via faston connectors. I found it easiest to disconnect the driver connectors, but removing them from the amplifier side works equally well.
      Ask FixBot
    3. Disassembling REL T5 Main Amplifier, Remove plate amp: step 3, image 1 of 1
      • You've now removed the plate amp. Set it aside on the heatsink side. The height of the heatsink will make sure that the controls are not damaged.
      • Now is a good time to check the voltage rails for residual voltage. Everything after the rectifier bridge should be <45V, but always take appropriate precautions when it comes to mains powered devices.
      Ask FixBot
    1. Disassembling REL T5 Main Amplifier, Snip all connecting trywraps: step 4, image 1 of 2 Disassembling REL T5 Main Amplifier, Snip all connecting trywraps: step 4, image 2 of 2
      • Snip all tywraps, such that all cables can be manipulated freely.
      Ask FixBot
    2. Disassembling REL T5 Main Amplifier, Disconnect connectors: step 5, image 1 of 2 Disassembling REL T5 Main Amplifier, Disconnect connectors: step 5, image 2 of 2
      • Disconnect all connectors that tie to the transformer
      • Make sure that all leads can be manipulated freely.
      Ask FixBot
    3. Disassembling REL T5 Main Amplifier, Loosen screws: step 6, image 1 of 2 Disassembling REL T5 Main Amplifier, Loosen screws: step 6, image 2 of 2
      • Start loosening the screws on the back using the m3 hex tool
      • Don't remove them fully, yet though.
      Ask FixBot
    4. Disassembling REL T5 Main Amplifier, Remove screws: step 7, image 1 of 2 Disassembling REL T5 Main Amplifier, Remove screws: step 7, image 2 of 2
      • Turn the amp on it's back.
      • Remove the nuts from the screws that where loosened on the back.
      • Remove the philips screws using a #2.
      Ask FixBot
    5. Disassembling REL T5 Main Amplifier, Loosen dampening rubber: step 8, image 1 of 1
      • Loosen the dampening rubber by running a Halberd Spudger underneath it.
      • The rubber is not adhered to the aluminium and is pretty tough, so a moderate amount of force is allowed.
      Ask FixBot
    6. Disassembling REL T5 Main Amplifier, Remove transformer: step 9, image 1 of 2 Disassembling REL T5 Main Amplifier, Remove transformer: step 9, image 2 of 2
      • You can now remove the transformer from the plate. Be careful not to damage the controls on the plate now that the assembly is a lot lighter.
      Ask FixBot
    1. Disassembling REL T5 Main Amplifier, Remove connectors: step 10, image 1 of 2 Disassembling REL T5 Main Amplifier, Remove connectors: step 10, image 2 of 2
      • Remove the connectors to the amp board.
      Ask FixBot
    2. Disassembling REL T5 Main Amplifier: step 11, image 1 of 2 Disassembling REL T5 Main Amplifier: step 11, image 2 of 2
      • Discharge the capacitor e.g. using a replacement 1k3 power resistor.
      • Carefully bridge the resistor across the + and - legs of the recifier, but don't touch anything else.
      Ask FixBot
      • Verify that the voltage is near zero. 0.2V or so is fine.
      • The voltage starts at around 100V, so be careful.
      Ask FixBot
    3. Disassembling REL T5 Main Amplifier, Remove component screws: step 13, image 1 of 2 Disassembling REL T5 Main Amplifier, Remove component screws: step 13, image 2 of 2
      • Remove the screws to the thermistor.
      • Remove the screws to the transistors.
      • Store them in a separate baggy.
      Ask FixBot
    4. Disassembling REL T5 Main Amplifier, Remove PCB screws: step 14, image 1 of 3 Disassembling REL T5 Main Amplifier, Remove PCB screws: step 14, image 2 of 3 Disassembling REL T5 Main Amplifier, Remove PCB screws: step 14, image 3 of 3
      • Remove screws for four corners.
      • Store them in or on their posts.
      Ask FixBot
    5. Disassembling REL T5 Main Amplifier, Lift the PCB: step 15, image 1 of 1
      • Gently lift up the PCB. The transistors might be held down by thermal paste, so use a spudger to release them.
      Ask FixBot
Author
with
Jasper van Zuijlen
1,200 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 79
All Time: 351
