Up to 20% off select tools
Disassembling Qualcomm QCP-2760 Rear Backing
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
95
All Time:
717
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Must remove battery first. Prerequisite to removal of antenna, motherboard and screen.
    1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: step 1, image 1 of 1
      • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
      • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
      Ask FixBot
    1. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: step 2, image 1 of 2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: step 2, image 2 of 2
      • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
      • Find the seam between the front and back of the phone
      • Pry the seam open using a plastic opening tool, or your fingers.
      • Some force is required
      Ask FixBot
Author
with
Xavier
313 Reputation
3 Guides authored
Ohio State, Team 1-4, Buehl Fall 2014 Member of Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 95
All Time: 717
