Up to 20% off select tools
Disassembling Power Mac G5 Side Panel
Views: 4.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
24
All Time:
4,093
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 minutes
Difficulty: Very easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
These instructions will show you the very first step into accessing the inside of the Apple G5.
    1. Disassembling Power Mac G5 Side Panel, Side Panel: step 1, image 1 of 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Ask FixBot
    2. Disassembling Power Mac G5 Side Panel: step 2, image 1 of 1
      • Remove all the cables, including the power cables before opening the unit.
      Ask FixBot
    3. Disassembling Power Mac G5 Side Panel: step 3, image 1 of 2 Disassembling Power Mac G5 Side Panel: step 3, image 2 of 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Ask FixBot
    4. Disassembling Power Mac G5 Side Panel: step 4, image 1 of 3 Disassembling Power Mac G5 Side Panel: step 4, image 2 of 3 Disassembling Power Mac G5 Side Panel: step 4, image 3 of 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
Jessica Chaidez
8,073 Reputation
3 Guides authored
Cal Poly, Team 5-8, Forte Winter 2010 Member of Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 24
All Time: 4,093
