Disassembling Power Mac G4 M5183 DVD-ROM Drive
Views: 13K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
117
All Time:
12,519
Comments: 2
2 comments on steps.
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide details the removal of the DVD-ROM from the disc drive tray.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 2, image 1 of 2 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 2, image 2 of 2
      • Removing the faceplate.
      • On the inside of the case, find the two plastic tabs.
      • While depressing the tabs, remove the faceplate by pulling and rotating outward.
      Ask FixBot
    2. Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 3, image 1 of 1
      • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
      Ask FixBot
    3. Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 1 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 2 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive: step 4, image 3 of 3
      • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
      • Remove both the power and ribbon cable.
      Ask FixBot
    1. Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 1 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 2 of 3 Disassembling Power Mac G4 M5183 DVD-ROM Drive, DVD-ROM Drive: step 5, image 3 of 3
      • Remove DVD drive from the drive bay.
      • Lift the two metal tabs on the back of the shielding and remove.
      • Remove the four screws on the bottom of the drive with the Phillips #1 screwdriver.
      • Slide out DVD drive.
      Ask FixBot
12 other people completed this guide.
Stephen Scruggs
2,283 Reputation
2 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 117
All Time: 12,519
