Up to 20% off select tools
Disassembling Polaroid a520 Lens
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
33
All Time:
1,549
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Disassembling Polaroid a520 Lens, Battery: step 1, image 1 of 2 Disassembling Polaroid a520 Lens, Battery: step 1, image 2 of 2
      • Place your thumb on the battery cover and push left towards the arrow.
      • The cover will release and pop open.
      Ask FixBot
    2. Disassembling Polaroid a520 Lens: step 2, image 1 of 1
      • Remove the batteries from the camera.
      Ask FixBot
    1. Disassembling Polaroid a520 Lens, Casing: step 3, image 1 of 1
      • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
      • This will release the front and back casings.
      Ask FixBot
    2. Disassembling Polaroid a520 Lens: step 4, image 1 of 1
      • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
      • Repeat this step for the back casing.
      Ask FixBot
    1. Disassembling Polaroid a520 Lens, LCD Screen: step 5, image 1 of 1
      • Under the screen, locate the black plastic strip that sits above the white plastic strip.
      Ask FixBot
    2. Disassembling Polaroid a520 Lens: step 6, image 1 of 1
      • Pull both sides of the black piece upward-about a mm.
      • The black plastic piece is not meant to come all the way off, just enough to release the screen.
      • Once the piece is lifted carefully slide the screen out of the slot.
      Ask FixBot
    1. Disassembling Polaroid a520 Lens, Logic Board: step 7, image 1 of 1
      • Unscrew and remove the four (6 mm) screws on the inside casing.
      Ask FixBot
    2. Disassembling Polaroid a520 Lens: step 8, image 1 of 1
      • Pull the inner casing off of the camera.
      Ask FixBot
    3. Disassembling Polaroid a520 Lens: step 9, image 1 of 1
      • Unscrew and remove the four (4mm) screws from the logic board.
      Ask FixBot
    4. Disassembling Polaroid a520 Lens: step 10, image 1 of 1
      • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
      Ask FixBot
    1. Disassembling Polaroid a520 Lens, Lens: step 11, image 1 of 1
      • Unscrew and remove the two (5mm) screws from the logic board to the far left.
      Ask FixBot
    2. Disassembling Polaroid a520 Lens: step 12, image 1 of 1
      • Locate the black plastic piece behind the lens.
      Ask FixBot
    3. Disassembling Polaroid a520 Lens: step 13, image 1 of 1
      • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
      • The piece will not come all the way off; only enough to release the lens.
      • Once the black piece is lifted slide the ribbon out to release the lens.
      Ask FixBot
Author
with
Dani
21 Reputation
7 Guides authored
Cal Poly, Team 3-3, Johann Summer 2010 Member of Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 33
All Time: 1,549
