Up to 20% off select tools
Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
Views: 11K
View statistics:
Past 24 Hours:
11
Past 7 Days:
57
Past 30 Days:
330
All Time:
11,448
Comments: 15
14 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Very difficult
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
After many requests, here is a video tutorial showing how to disassembly a PlayStation Vita's Screen & Digitizer from its front plastic frame assembly.
Video Overview
    1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: step 1, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: step 1, image 2 of 2
      • Power off and remove the memory card.
      • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
      Ask FixBot
    2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 2, image 3 of 3
      • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
      • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
      Ask FixBot
    3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 3, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 3, image 2 of 2
      • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
      Ask FixBot
    4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 4, image 3 of 3
      • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
      • Continue working your way around the device gently prying it open.
      • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
      Ask FixBot
    5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 5, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 5, image 2 of 2
      • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
      Ask FixBot
    6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 6, image 1 of 1
      • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
      Ask FixBot
    7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 7, image 1 of 1
      • Free the battery cable by gently prying up on the connection with a spudger.
      Ask FixBot
    8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 8, image 1 of 1
      • Separate the front and rear cases.
      Ask FixBot
    1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: step 9, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: step 9, image 2 of 2
      • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
      • The easiest access to the battery cable retainer is where the battery cable comes out.
      • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
      Ask FixBot
    2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 10, image 1 of 2 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 10, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
      • Remove the plastic battery retaining bar.
      Ask FixBot
    3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 1 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 2 of 3 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): step 11, image 3 of 3
      • Using your finger or a spudger, lift the battery out and remove it.
      • Guide the battery wires through the hole in the back casing as you remove the battery.
      Ask FixBot
7 other people completed this guide.
Author
with
djgodmandj
302 Reputation
1 Guide authored
1 Guide Comment
So is there any chance that this could be used as a modding possibility, where we could install a higher resolution /quality screen?
TheHeavy - Reply Share
Past 24 Hours: 11
Past 7 Days: 57
Past 30 Days: 330
All Time: 11,448
