Up to 20% off select tools
Disassembling PlayStation Controller SCPH-1080
Views: 2.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
67
Past 30 Days:
279
All Time:
2,299
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is how I disassemble my PlayStation controller for cleaning. This is not a repair guide or for any electronics explanations.
    1. Disassembling PlayStation Controller SCPH-1080, SCPH-1080: step 1, image 1 of 3 Disassembling PlayStation Controller SCPH-1080, SCPH-1080: step 1, image 2 of 3 Disassembling PlayStation Controller SCPH-1080, SCPH-1080: step 1, image 3 of 3
      • Turn the controller onto its front and remove the 8 screws in the holes, 4 on each side.
      • Remove the bottom half of the controllers shell.
      • The screws are all the same size so no need to replace in the same holes, just be careful they dont get lost.
      Ask FixBot
    2. Disassembling PlayStation Controller SCPH-1080: step 2, image 1 of 2 Disassembling PlayStation Controller SCPH-1080: step 2, image 2 of 2
      • Start in the bottom half of the shell.
      • The L2 & R2 buttons are held in place by a bracket with 1 silver screw each, remove the screws.
      • The brackets and buttons should come out when turned over or with very little force.
      • Keep these screws separate from the 8 shell screws.
      Ask FixBot
    3. Disassembling PlayStation Controller SCPH-1080: step 3, image 1 of 3 Disassembling PlayStation Controller SCPH-1080: step 3, image 2 of 3 Disassembling PlayStation Controller SCPH-1080: step 3, image 3 of 3
      • Now go back to the top half of the controller shell which contains the PCB.
      • Note the L1 and R1 cable route, they sit in slits to help keep them safe.
      • Remove the L1 and R1 brackets by lifting them up and out, they can sometimes be slightly stuck in place but a small jiggle helps.
      • Now lift the buttons and PCB out of the shell.
      Ask FixBot
    4. Disassembling PlayStation Controller SCPH-1080: step 4, image 1 of 3 Disassembling PlayStation Controller SCPH-1080: step 4, image 2 of 3 Disassembling PlayStation Controller SCPH-1080: step 4, image 3 of 3
      • Next we can remove the other buttons.
      • They contain multiple layers of rubber and plastic and can be tipped out or pulled out easy enough.
      Ask FixBot
    5. Disassembling PlayStation Controller SCPH-1080: step 5, image 1 of 2 Disassembling PlayStation Controller SCPH-1080: step 5, image 2 of 2
      • The L1 and R1 buttons can be pulled out of their brackets.
      • Grasp the dark grey button firmly, wiggle and pull them out.
      • This will not break them if they are in good health.
      • You will see they have very small catches, just enough to keep them in when in use.
      • That is as far as I go for cleaning my controllers.
      Ask FixBot
I washed my controller plastic and rubber parts in warm soapy water using an old toothbrush, left to dry fully and then reassembled.
To reassemble your device, follow these instructions in reverse order, ensuring cables are replaced into their designed routes to help prevent any damage when closing the controller back up.
2 other people completed this guide.
Author
with
DinoPilot
178 Reputation
1 Guide authored
1 Guide Comment
what JIS screwdriver is needed for the screws for this controller please ?
Khalid EL ALLALI - Reply Share
Past 24 Hours: 7
Past 7 Days: 67
Past 30 Days: 279
All Time: 2,299
