Disassembling PlayStation 5 HD Camera Base of the HD camera
  1. Disassembling PlayStation 5 HD Camera Base of the HD camera, Remove bottom plastic cover: step 1, image 1 of 1
    • Starting at the back use a plastic pry tool (spudger) and slide the tool forwards towards the rubber foot.
    Ask FixBot
  2. Disassembling PlayStation 5 HD Camera Base of the HD camera, Remove bottom plastic cover: step 2, image 1 of 1
    • As you slide the tool forwards, the bottom of the plastic base should come away
    Ask FixBot
  3. Disassembling PlayStation 5 HD Camera Base of the HD camera, Repeat for the other side: step 3, image 1 of 1
    • Repeat the process for the other side, again starting at the back. And the plastic base of the camera should come off easily.
    Ask FixBot
  4. Disassembling PlayStation 5 HD Camera Base of the HD camera, Remove rubber foot and metal base: step 4, image 1 of 1
    • Pull the rubber foot forwards to release it from the three catches on base of the camera.
    • The metal base and rubber foot are one piece.
    Ask FixBot
  5. Disassembling PlayStation 5 HD Camera Base of the HD camera, This completes dissasembly of the camera base: step 5, image 1 of 1
    • With the base dissassembled the parts can be more easily modified to accept a 1/4 inch thread for a tripod mount.
    Ask FixBot
  6. Disassembling PlayStation 5 HD Camera Base of the HD camera, Reassembly: step 6, image 1 of 1
    • Slide rubber foot with metal back onto the three platic clips
    Ask FixBot
  7. Disassembling PlayStation 5 HD Camera Base of the HD camera, Reassembly plastic base cover: step 7, image 1 of 1
    • Push the cover on at the back until you hear a click sound
    • Then push the front of the plastic each side to click it into place
    Ask FixBot
Corporatezombi
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 44
All Time: 169
