Up to 20% off select tools
Disassembling PlayStation 2 Slimline Outer Shell
Views: 17K
View statistics:
Past 24 Hours:
15
Past 7 Days:
81
Past 30 Days:
329
All Time:
16,867
Comments: 3
3 guide comments.
Go to guide comments
Completed: 23
23 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Disassembling PlayStation 2 Slimline Outer Shell, Outer Shell: step 1, image 1 of 1
      • Disconnect all cables from the console and flip the unit over to reveal its base.
      Ask FixBot
    2. Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 3 of 3
      • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
      • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
      Ask FixBot
    3. Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 3 of 3
      • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
      Ask FixBot
    4. Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 3 of 3
      • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
      • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
      Ask FixBot
23 other people completed this guide.
Author
with
Thomas Sullivan
4,876 Reputation
6 Guides authored
3 Guide Comments
Just to clarify: in order to FULLY remove the bottom half of the shell on my PS2 Slim, I had to remove a screw that pinned the controller ports in place; it's at the front, right between the Player 1 and Player 2 ports.
Other than that, this guide worked perfectly! :D
Kizul Emeraldfire - Reply Share
Good morning. Hello. The disassembly of the PS2 series 7XXXX (PS2 Slim) is very well explained, except for one detail. Indeed, when I started to separate the bottom from the top, a small metal plate with a threaded hole in the center. And I find no mention of it anywhere. Considering the part, I think it's used by one of the screws that holds the two plastic hulls, but I don't see where. Can you help me, please? Friendly, Marc.
Translated with www.DeepL.com/Translator
Marc Blériot - Reply Share
The metal plate with a screw hole in the middle is for the stand-up-base-stand to be screwed down. It’s an after market item SONY sold seperately.
김동현 - Reply Share
Past 24 Hours: 15
Past 7 Days: 81
Past 30 Days: 329
All Time: 16,867
