Up to 20% off select tools
Disassembling Planet Eclipse Geo3 Body
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
95
All Time:
1,296
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to separate the body into the trigger frame and the bolt frame. This will allow you to access the solenoid and eyes.
    1. Disassembling Planet Eclipse Geo3 Body, Grip: step 1, image 1 of 2 Disassembling Planet Eclipse Geo3 Body, Grip: step 1, image 2 of 2
      • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
      Ask FixBot
    2. Disassembling Planet Eclipse Geo3 Body: step 2, image 1 of 2 Disassembling Planet Eclipse Geo3 Body: step 2, image 2 of 2
      • Pull the grip away from the frame.
      Ask FixBot
    3. Disassembling Planet Eclipse Geo3 Body: step 3, image 1 of 2 Disassembling Planet Eclipse Geo3 Body: step 3, image 2 of 2
      • Pull the grip through the opening.
      • The grip is connected in the middle and is one piece.
      Ask FixBot
    1. Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 1 of 3 Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 2 of 3 Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 3 of 3
      • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
      • It helps to rotate the collar to create room to pull out macroline.
      Ask FixBot
    2. Disassembling Planet Eclipse Geo3 Body: step 5, image 1 of 3 Disassembling Planet Eclipse Geo3 Body: step 5, image 2 of 3 Disassembling Planet Eclipse Geo3 Body: step 5, image 3 of 3
      • While pulling in the metal ring on the fitting, pull the macroline out.
      Ask FixBot
    1. Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 1 of 3 Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 2 of 3 Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 3 of 3
      • Use 1/8" allen wrench to remove screw behind regulator.
      Ask FixBot
    2. Disassembling Planet Eclipse Geo3 Body: step 7, image 1 of 3 Disassembling Planet Eclipse Geo3 Body: step 7, image 2 of 3 Disassembling Planet Eclipse Geo3 Body: step 7, image 3 of 3
      • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
      • The screw only needs to be turned a couple of times.
      • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
      • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
      Ask FixBot
Author
with
Rett Triplett
801 Reputation
8 Guides authored
Clemson, Team 13-6, Benson Fall 2013 Member of Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 95
All Time: 1,296
