Up to 20% off select tools
Disassembling Planet Eclipse Etha Frame
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
101
All Time:
983
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Removing the frame will allow access to the eyes and solenoid should they need replacement.
    1. Disassembling Planet Eclipse Etha Frame, Regulator: step 1, image 1 of 2 Disassembling Planet Eclipse Etha Frame, Regulator: step 1, image 2 of 2
      • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
      • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
      • The macroline is the black hose connecting the regulator to the tank connection.
      Ask FixBot
    2. Disassembling Planet Eclipse Etha Frame: step 2, image 1 of 2 Disassembling Planet Eclipse Etha Frame: step 2, image 2 of 2
      • Remove the regulator by unscrewing it in a clockwise direction.
      Ask FixBot
    1. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: step 3, image 1 of 2 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: step 3, image 2 of 2
      • Use the 5/64" hex key to remove the screw shown.
      • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
      • If you are only replacing the battery, skip the next step.
      • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
      Ask FixBot
    2. Disassembling Planet Eclipse Etha Frame: step 4, image 1 of 1
      • Flip the marker over and use the 5/64" hex key to remove the screw shown.
      Ask FixBot
    3. Disassembling Planet Eclipse Etha Frame: step 5, image 1 of 2 Disassembling Planet Eclipse Etha Frame: step 5, image 2 of 2
      • Carefully remove the 9V battery and connector.
      • Remove the 9V battery from the connector.
      Ask FixBot
    1. Disassembling Planet Eclipse Etha Frame, Frame: step 6, image 1 of 2 Disassembling Planet Eclipse Etha Frame, Frame: step 6, image 2 of 2
      • Carefully disconnect the three connectors from the circuit board.
      • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
      Ask FixBot
    2. Disassembling Planet Eclipse Etha Frame: step 7, image 1 of 2 Disassembling Planet Eclipse Etha Frame: step 7, image 2 of 2
      • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
      Ask FixBot
    3. Disassembling Planet Eclipse Etha Frame: step 8, image 1 of 1
      • Be very careful during the step to avoid damage to the solenoid or wiring.
      • Gently separate the top and bottom of the marker.
      Ask FixBot
Author
with
nicholasj6
261 Reputation
2 Guides authored
Cal Poly, Team 10-42, Amido Fall 2014 Member of Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 101
All Time: 983
