Disassembling Pentax PZ-10 Top Cover
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
1,610
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide is a prerequisite guide to enable access to features under the top casing for maintenance, repair, and replacement. The top cover encases the top features of the device except the flash and shutter button.
Tools
    1. Disassembling Pentax PZ-10 Top Cover, Top Cover: step 1, image 1 of 1
      • The top cover is one piece encasing the top of the device except the shutter release button and flash.
      Ask FixBot
    2. Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: step 2, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: step 2, image 2 of 2
      • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
      • Using the J0 screwdriver, remove the 6.3 mm screw.
      Ask FixBot
    3. Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: step 3, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: step 3, image 2 of 2
      • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
      • Remove the 6.3 mm screw using a J0 screwdriver.
      Ask FixBot
    4. Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: step 4, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: step 4, image 2 of 2
      • The next screw is found in the overhanging piece just above the lens.
      • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
      Ask FixBot
    5. Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: step 5, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: step 5, image 2 of 2
      • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
      Ask FixBot
2 other people completed this guide.
Jonathan Diaz
213 Reputation
2 Guides authored
1 Guide Comment
Thank you! Well done sir!
michaelsteele1953 - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,610
