Disassembling Panasonic Lumix DMC-TZ5 Back Cover
Views: 7.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
7,939
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Since this is step one, you will just need to start with your camera.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Disassembling Panasonic Lumix DMC-TZ5 Back Cover, Back Cover: step 1, image 1 of 1
      • Remove the battery and memory card from the device.
      Ask FixBot
    2. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 2, image 1 of 1
      • Remove 4 screws from the right side of the camera.
      • There are two 3.4mm screws at the top.
      • There are two 2.2mm screws at the bottom.
      Ask FixBot
    3. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 3, image 1 of 1
      • Remove the single 3.4mm screw on the left side of the camera.
      Ask FixBot
    4. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 4, image 1 of 1
      • Remove 5 screws from the base of the camera.
      • There are two 2.2mm screws next to the battery compartment.
      • There are three 4mm screws around the tripod mount.
      Ask FixBot
    5. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 5, image 1 of 1
      • Slowly slide the back cover away from the device
      • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
      Ask FixBot
    6. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 6, image 1 of 2 Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 6, image 2 of 2
      • Detach both ribbon cables using a spudger.
      • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
      Ask FixBot
    7. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: step 7, image 1 of 1
      • Remove the back casing from the camera.
      Ask FixBot
4 other people completed this guide.
Ben Canfield
424 Reputation
3 Guides authored
Cal Poly, Team 9-21, Regan Fall 2010 Member of Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 Members
84 Guides authored
1 Guide Comment
That is not a disassembly! All is shows is taking the back of the camera off. How about showing how to disassembly the camera down to its individual components and make repairs, like getting the lens to extend of fixing a sticking shutter.
JR Tan - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 7,939
