Up to 20% off select tools
Disassembling Panasonic GU87 Main-LCD
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
22
All Time:
1,628
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Panasonic GU87 Main-LCD, LCD Cover removal: step 1, image 1 of 1
      • Remove the four rubber screw covers from encircled locations.
      • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
      • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
      Ask FixBot
    2. Disassembling Panasonic GU87 Main-LCD: step 2, image 1 of 1
      • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
      • Be mindful of location and magnitude of applied force, so as not to damage the case.
      Ask FixBot
    1. Disassembling Panasonic GU87 Main-LCD, LCD: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
      Ask FixBot
    2. Disassembling Panasonic GU87 Main-LCD: step 4, image 1 of 1
      • Use fingernails to pry off minor LCD mount, as shown.
      • Remove the minor LCD
      Ask FixBot
    1. Disassembling Panasonic GU87 Main-LCD, Main Board: step 5, image 1 of 1
      Buy
      • Unlock the LCD connectors shown in red boxes on the picture .
      • Use tweezers as necessary.
      Ask FixBot
    2. Disassembling Panasonic GU87 Main-LCD: step 6, image 1 of 1
      • Place finger nails on the connector tab as shown.
      • Lift the connector tab up.
      Ask FixBot
    3. Disassembling Panasonic GU87 Main-LCD: step 7, image 1 of 1
      • Pull/pivot the LCD main board as shown in order to remove.
      Ask FixBot
    1. Disassembling Panasonic GU87 Main-LCD, Disassembling Panasonic GU87 Main-LCD: step 8, image 1 of 1
      Buy
      Ask FixBot
Author
with
Van
7 Reputation
8 Guides authored
Cal Poly, Team 2-10, Johann Summer 2010 Member of Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 1,628
