Disassembling Panasonic GU87 LCD Main Board
    1. Disassembling Panasonic GU87 LCD Main Board, LCD Cover removal: step 1, image 1 of 1
      • Remove the four rubber screw covers from encircled locations.
      • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
      • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
      Ask FixBot
    2. Disassembling Panasonic GU87 LCD Main Board: step 2, image 1 of 1
      • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
      • Be mindful of location and magnitude of applied force, so as not to damage the case.
      Ask FixBot
    1. Disassembling Panasonic GU87 LCD Main Board, LCD: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
      Ask FixBot
    2. Disassembling Panasonic GU87 LCD Main Board: step 4, image 1 of 1
      • Use fingernails to pry off minor LCD mount, as shown.
      • Remove the minor LCD
      Ask FixBot
    1. Disassembling Panasonic GU87 LCD Main Board, Main Board: step 5, image 1 of 1
      Buy
      • Unlock the LCD connectors shown in red boxes on the picture .
      • Use tweezers as necessary.
      Ask FixBot
    2. Disassembling Panasonic GU87 LCD Main Board: step 6, image 1 of 1
      • Place finger nails on the connector tab as shown.
      • Lift the connector tab up.
      Ask FixBot
    3. Disassembling Panasonic GU87 LCD Main Board: step 7, image 1 of 1
      • Pull/pivot the LCD main board as shown in order to remove.
      Ask FixBot
Van
7 Reputation
8 Guides authored
Cal Poly, Team 2-10, Johann Summer 2010 Member of Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 2,180
