Up to 20% off select tools
Disassembling Palm Centro Logic Board
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
90
All Time:
3,859
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This will guide you on how to disassemble the Palm Centro to get to the logic board.
    1. Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: step 1, image 1 of 2 Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: step 1, image 2 of 2
      • Press and slide open the battery cover.
      Ask FixBot
    2. Disassembling Palm Centro Logic Board: step 2, image 1 of 1
      • Caution: Turn cell phone off before removing battery!
      • Press battery to the right.
      • Then lift up battery pack to remove.
      Ask FixBot
    3. Disassembling Palm Centro Logic Board: step 3, image 1 of 1
      • Phone with battery removed
      Ask FixBot
    1. Disassembling Palm Centro Logic Board, Back Housing: step 4, image 1 of 1
      • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
      Ask FixBot
    2. Disassembling Palm Centro Logic Board: step 5, image 1 of 1
      • Lift the rubber cap at the top right to reveal the sixth screw.
      • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
      • Remove the six screws using the T5 Torx screwdriver.
      Ask FixBot
    3. Disassembling Palm Centro Logic Board: step 6, image 1 of 2 Disassembling Palm Centro Logic Board: step 6, image 2 of 2
      • Remove the SIM card so housing can be separated.
      Ask FixBot
    4. Disassembling Palm Centro Logic Board: step 7, image 1 of 2 Disassembling Palm Centro Logic Board: step 7, image 2 of 2
      • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
      Ask FixBot
    5. Disassembling Palm Centro Logic Board: step 8, image 1 of 2 Disassembling Palm Centro Logic Board: step 8, image 2 of 2
      • Remove the small plastic insert at the bottom of the phone.
      Ask FixBot
    6. Disassembling Palm Centro Logic Board: step 9, image 1 of 2 Disassembling Palm Centro Logic Board: step 9, image 2 of 2
      • Continue with plastic pry tool all the way around the phone to remove the back housing.
      Ask FixBot
    1. Disassembling Palm Centro Logic Board, Logic Board: step 10, image 1 of 1
      • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
      Ask FixBot
    2. Disassembling Palm Centro Logic Board: step 11, image 1 of 1
      • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
      • Be very careful, these electronics are delicate!
      Ask FixBot
    3. Disassembling Palm Centro Logic Board: step 12, image 1 of 1
      • Separate the logic board from the case by lifting and pulling out the bottom.
      Ask FixBot
Author
with
Chelsea Barackman
42 Reputation
3 Guides authored
Cal Poly, Team 15-49, Garner Spring 2010 Member of Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Members
72 Guides authored
2 Guide Comments
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - Reply Share
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
kelumaruna - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 90
All Time: 3,859
