Disassembling Olympus Stylus 725 SW Side Panels
    1. Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: step 1, image 1 of 2 Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: step 1, image 2 of 2
      • The battery is located on the bottom of the camera.
      • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
      • If the battery is dead, charge it for 60-90 minutes.
      • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
      Ask FixBot
    1. Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: step 2, image 1 of 3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: step 2, image 2 of 3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: step 2, image 3 of 3
      • Remove the top screws using a 1.5 mm screwdriver.
      • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
      Ask FixBot
    1. Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: step 3, image 1 of 3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: step 3, image 2 of 3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: step 3, image 3 of 3
      • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
      Ask FixBot
    2. Disassembling Olympus Stylus 725 SW Side Panels: step 4, image 1 of 3 Disassembling Olympus Stylus 725 SW Side Panels: step 4, image 2 of 3 Disassembling Olympus Stylus 725 SW Side Panels: step 4, image 3 of 3
      • After removing all four of the screws, pry the side covers off of the camera.
      Ask FixBot
Bobby Hodges
49 Reputation
6 Guides authored
Cal Poly, Team 33-71, Johann Spring 2010 Member of Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 27
All Time: 3,331
