Disassembling Olympus Stylus 725 SW Battery
Views: 4.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
107
All Time:
4,306
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide to remove the battery in order to charge it, or do extensive work on the camera.
    1. Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: step 1, image 1 of 2 Disassembling Olympus Stylus 725 SW Battery, Disassembling Olympus Stylus 725 SW Battery: step 1, image 2 of 2
      • The battery is located on the bottom of the camera.
      • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
      • If the battery is dead, charge it for 60-90 minutes.
      • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
      Ask FixBot
Follow these instructions in reverse order to reassemble your device.
Bobby Hodges
49 Reputation
6 Guides authored
Cal Poly, Team 33-71, Johann Spring 2010 Member of Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 107
All Time: 4,306
