Up to 20% off select tools
Disassembling Olympus Stylus 1010 Case
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
110
All Time:
4,057
Comments: 9
8 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: step 1, image 1 of 2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: step 1, image 2 of 2
      • Remove the five Phillips #00 bottom and right side panel screws.
      Ask FixBot
    2. Disassembling Olympus Stylus 1010 Case: step 2, image 1 of 1
      • Remove the right side panel by pulling off the large silver piece.
      Ask FixBot
    3. Disassembling Olympus Stylus 1010 Case: step 3, image 1 of 2 Disassembling Olympus Stylus 1010 Case: step 3, image 2 of 2
      • Remove the remaining three Phillips #00 side and front panel screws.
      Ask FixBot
    4. Disassembling Olympus Stylus 1010 Case: step 4, image 1 of 1
      • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
      Ask FixBot
    5. Disassembling Olympus Stylus 1010 Case: step 5, image 1 of 1
      • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
      Ask FixBot
    6. Disassembling Olympus Stylus 1010 Case: step 6, image 1 of 3 Disassembling Olympus Stylus 1010 Case: step 6, image 2 of 3 Disassembling Olympus Stylus 1010 Case: step 6, image 3 of 3
      • Remove the three Phillips #00 screws from the front of the camera.
      • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
      Ask FixBot
    7. Disassembling Olympus Stylus 1010 Case: step 7, image 1 of 3 Disassembling Olympus Stylus 1010 Case: step 7, image 2 of 3 Disassembling Olympus Stylus 1010 Case: step 7, image 3 of 3
      • Using a plastic spudger, lift up the black clips.
      • Still using the plastic spudger, detach the gold connector strip and white connector strip.
      • Using both hands, pull the camera apart into two pieces.
      Ask FixBot
Author
with
Max McIntyre
544 Reputation
4 Guides authored
Cal Poly, Team 13-4, Forte Winter 2011 Member of Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Members
72 Guides authored
1 Guide Comment
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 110
All Time: 4,057
