Up to 20% off select tools
Disassembling Olympus FE-170 Casing
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
99
All Time:
1,293
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Olympus FE-170 Casing, Casing: step 1, image 1 of 2 Disassembling Olympus FE-170 Casing, Casing: step 1, image 2 of 2
      • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
      Ask FixBot
    2. Disassembling Olympus FE-170 Casing: step 2, image 1 of 2 Disassembling Olympus FE-170 Casing: step 2, image 2 of 2
      • Open the battery compartment and remove the 2 screws in the top of the opening.
      Ask FixBot
    3. Disassembling Olympus FE-170 Casing: step 3, image 1 of 2 Disassembling Olympus FE-170 Casing: step 3, image 2 of 2
      • Remove the 2 exposed screws on the bottom of the camera.
      Ask FixBot
    4. Disassembling Olympus FE-170 Casing: step 4, image 1 of 1
      • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
      Ask FixBot
    5. Disassembling Olympus FE-170 Casing: step 5, image 1 of 1
      • Uncover the video cable port on the side of the camera and remove the screw
      Ask FixBot
    6. Disassembling Olympus FE-170 Casing: step 6, image 1 of 2 Disassembling Olympus FE-170 Casing: step 6, image 2 of 2
      • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
      Ask FixBot
    7. Disassembling Olympus FE-170 Casing: step 7, image 1 of 2 Disassembling Olympus FE-170 Casing: step 7, image 2 of 2
      • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
      Ask FixBot
    8. Disassembling Olympus FE-170 Casing: step 8, image 1 of 2 Disassembling Olympus FE-170 Casing: step 8, image 2 of 2
      • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
      Ask FixBot
Author
with
CCrane
201 Reputation
2 Guides authored
Baylor, Team 6-4, Shaver Spring 2015 Member of Baylor, Team 6-4, Shaver Spring 2015
BU-SHAVER-S15S6G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 99
All Time: 1,293
