Up to 20% off select tools
Disassembling Numark TT1600 Circuit board
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
7
Past 30 Days:
34
All Time:
2,026
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Disassembling Numark TT1600 Circuit board, Circuit board: step 1, image 1 of 2 Disassembling Numark TT1600 Circuit board, Circuit board: step 1, image 2 of 2
      • Flip over the turntable and remove the nine screws on the outer edges.
      Ask FixBot
    2. Disassembling Numark TT1600 Circuit board: step 2, image 1 of 1
      • Remove the back cover by pulling it apart.
      Ask FixBot
    3. Disassembling Numark TT1600 Circuit board: step 3, image 1 of 1
      • Locate the largest circuit board inside the device.
      Ask FixBot
    4. Disassembling Numark TT1600 Circuit board: step 4, image 1 of 1
      • Locate the wires that are plugged into the side of the circuit board.
      Ask FixBot
    5. Disassembling Numark TT1600 Circuit board: step 5, image 1 of 2 Disassembling Numark TT1600 Circuit board: step 5, image 2 of 2
      • Gently pull out the wires plugged into the circuit board.
      Ask FixBot
    6. Disassembling Numark TT1600 Circuit board: step 6, image 1 of 2 Disassembling Numark TT1600 Circuit board: step 6, image 2 of 2
      • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
      • Note that these wires are soldered onto the circuit, indicated by the red markers.
      • To completely remove the circuit board these wires must be removed.
      Ask FixBot
Author
with
Sukhjinder
17 Reputation
1 Guide authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 2,026
