Up to 20% off select tools
Disassembling Novation Launchpad Mk2
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
110
All Time:
764
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
      • Remove rubber mat on the bottom of the device using spudger or the tip of a screwdriver. Please remove the mat with care, do not use much force to prevent tears in the material. Optionally use the opening picks to make the mat not stick to the shell again.
      Ask FixBot
      • Remove 7 screws under the rubber mat.
      Ask FixBot
      • Separate the clips near handles of the launchpad shell using spudger or similar tool. Place the opening picks in the gaps of corners to ease the access to the clips. Do not apply much force to prevent breaking the clips.
      Ask FixBot
      • Remove the bottom of the launchpad shell. Separate the launchpad into 4 layers. (Bottom case, PCB, rubber mat with button pads, top case)
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Please note the glue on the rubber mat will dry up when left in the air for too long.
Author
with
birb
139 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 110
All Time: 764
