Up to 20% off select tools
Disassembling Nokia X2-00
Views: 6.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
31
Past 30 Days:
119
All Time:
6,519
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
i'll show you how to tear it down (without removing unnessesary parts like i did)
I'm not professional, so my lighting and photo quality isn't Perfect, i just don't have money to invest
    1. Disassembling Nokia X2-00, Nokia X2-00 Background Info: step 1, image 1 of 1
      • it's a cheap low-end Music Phone
      • mine got wet so i decided to clean it up and look inside!
      Ask FixBot
    2. Disassembling Nokia X2-00, Removing the Battery: step 2, image 1 of 3 Disassembling Nokia X2-00, Removing the Battery: step 2, image 2 of 3 Disassembling Nokia X2-00, Removing the Battery: step 2, image 3 of 3
      • Flip it and pull the tab
      • the metal part should jump right off
      • after that remove the battery and sim card
      Ask FixBot
    3. Disassembling Nokia X2-00, Diging In!: step 3, image 1 of 1
      • so i was kinda !#^&@@ off becouse there were no screws!
      • so i tryed to remove the screen protection, and it worked!
      • 1. i did break it
      • 2. there were no screws
      • just don't do that unless you need
      Ask FixBot
    4. Disassembling Nokia X2-00, Diging In! 2nd attemp!: step 4, image 1 of 2 Disassembling Nokia X2-00, Diging In! 2nd attemp!: step 4, image 2 of 2
      • i tried to remove the side panels but that didn't work so i tried on top and it did work (Jimmy worked fine)
      • these clips kind of suck ....it takes lot of force to unclip these )
      • after you unclip it you get that piece
      Ask FixBot
    5. Disassembling Nokia X2-00, Removing the midframe: step 5, image 1 of 3 Disassembling Nokia X2-00, Removing the midframe: step 5, image 2 of 3 Disassembling Nokia X2-00, Removing the midframe: step 5, image 3 of 3
      • remove these 2 TR6 Screws (mine were a bit blue)
      • open it up (clips on the bottom)
      • i was on Beast-Mode on these annying clips that held like gorilla
      Ask FixBot
    6. Disassembling Nokia X2-00, Removing the display: step 6, image 1 of 3 Disassembling Nokia X2-00, Removing the display: step 6, image 2 of 3 Disassembling Nokia X2-00, Removing the display: step 6, image 3 of 3
      • Remove the 4 TR6 Screws
      • They are diffrent from the last ones !!! (this one on the right)
      • remove the whole PCB and remove the clips from the display and it should pop off
      Ask FixBot
    7. Disassembling Nokia X2-00, The Display: step 7, image 1 of 2 Disassembling Nokia X2-00, The Display: step 7, image 2 of 2
      • it's TFT 2.2" 240x320 182 ppi Display
      Ask FixBot
    8. Disassembling Nokia X2-00, The main PCB: step 8, image 1 of 1
      • anything shiehielded ...and non-replacable ...i don't like that one at all
      • sorry guys i have forgott to make photo of the backside :(
      Ask FixBot
    9. Disassembling Nokia X2-00, Extra - Mastery pieces & Test: step 9, image 1 of 2 Disassembling Nokia X2-00, Extra - Mastery pieces & Test: step 9, image 2 of 2
      • extra steps that you don't need to do
      • 2 of those fell of and i have NO idea where from (and i don't even care)
      • i cleaned it up and powered it up and it works (just make sure you don't short anything)
      Ask FixBot
    10. Disassembling Nokia X2-00, The END: step 10, image 1 of 1
      • i don't really like that one becouse it's hard to open and easy to crack plastics
      • but you can replace many things (not anything)
      • i would like USB on doughterboard and less shielding
      Ask FixBot
Finish Line
10 other people completed this guide.
Author
with
Mateusz
1,525 Reputation
2 Guides authored
1 Guide Comment
Well done,come on
Segmenttopten - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 119
All Time: 6,519
