Up to 20% off select tools
Disassembling Nokia E71 Complete disassembly
Views: 36K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
169
All Time:
35,859
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 33
33 people have marked this guide "completed." Will you be next?
Favorites: 34
34 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Disassembling Nokia E71 Complete disassembly, Disassembling Nokia E71 Complete disassembly: step 1, image 1 of 1
      • First remove back cover, battery, chip and memory card .
      Ask FixBot
    2. Disassembling Nokia E71 Complete disassembly: step 2, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 2, image 2 of 2
      • Remove 4 Torx T5 screws.
      Ask FixBot
    3. Disassembling Nokia E71 Complete disassembly: step 3, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 3, image 2 of 2
      • Press these four latches (each side has two) to open front cover.
      Ask FixBot
    4. Disassembling Nokia E71 Complete disassembly: step 4, image 1 of 1
      • Carefully remove the front cover with blade tool.
      Ask FixBot
    5. Disassembling Nokia E71 Complete disassembly: step 5, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 5, image 2 of 2
      • Carefully remove the bottom cover. This cover has no screws, only latches.
      Ask FixBot
    6. Disassembling Nokia E71 Complete disassembly: step 6, image 1 of 1
      • Front cover, rubber keyboard and bottom cover removed.
      Ask FixBot
    7. Disassembling Nokia E71 Complete disassembly: step 7, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 7, image 2 of 2
      • Remove these two Torx T6 screws at top of the smartphone.
      Ask FixBot
    8. Disassembling Nokia E71 Complete disassembly: step 8, image 1 of 1
      • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
      Ask FixBot
    9. Disassembling Nokia E71 Complete disassembly: step 9, image 1 of 1
      • Base assembly with small connectors and parts.
      Ask FixBot
    10. Disassembling Nokia E71 Complete disassembly: step 10, image 1 of 1
      • Remove the LCD connector.
      Ask FixBot
    11. Disassembling Nokia E71 Complete disassembly: step 11, image 1 of 1
      • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
      Ask FixBot
    12. Disassembling Nokia E71 Complete disassembly: step 12, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 12, image 2 of 2
      • Both sides of the LCD and keyboard assembly removed.
      Ask FixBot
    13. Disassembling Nokia E71 Complete disassembly: step 13, image 1 of 1
      • I think that two small blocks are the gps antenna.
      Ask FixBot
    14. Disassembling Nokia E71 Complete disassembly: step 14, image 1 of 2 Disassembling Nokia E71 Complete disassembly: step 14, image 2 of 2
      • Both sides of battery - for reference only.
      Ask FixBot
33 other people completed this guide.
Author
with
Jose Gustavo Abreu Murta
5,212 Reputation
9 Guides authored
4 Guide Comments
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - Reply Share
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt - Reply Share
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - Reply Share
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
James Burton - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 169
All Time: 35,859
