Up to 20% off select tools
Disassembling Nokia E61i Keyboard
Views: 2.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
88
All Time:
2,369
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
    1. Disassembling Nokia E61i Keyboard, Battery: step 1, image 1 of 2 Disassembling Nokia E61i Keyboard, Battery: step 1, image 2 of 2
      • First, gather all necessary tools.
      • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
      • Slide the back cover downwards off of the phone while pressing down on the tab.
      Ask FixBot
    2. Disassembling Nokia E61i Keyboard: step 2, image 1 of 1
      • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
      Ask FixBot
    3. Disassembling Nokia E61i Keyboard: step 3, image 1 of 1
      • Lift the battery out using your finger.
      • The E61i uses a Nokia BP-4L standard battery.
      Ask FixBot
    1. Disassembling Nokia E61i Keyboard, Front Cover: step 4, image 1 of 2 Disassembling Nokia E61i Keyboard, Front Cover: step 4, image 2 of 2
      • To remove the top of the back cover, pry the sides and pop it off.
      • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
      Ask FixBot
    2. Disassembling Nokia E61i Keyboard: step 5, image 1 of 1
      • Remove the cover by pulling it up and off.
      Ask FixBot
    1. Disassembling Nokia E61i Keyboard, Keyboard: step 6, image 1 of 1
      • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
      Ask FixBot
Author
with
Christopher Patton
208 Reputation
12 Guides authored
Cal Poly, Team 9-63, Walters Spring 2011 Member of Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 88
All Time: 2,369
