Up to 20% off select tools
Disassembling Nokia 6236i Display
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
77
All Time:
2,281
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide helps you remove the display from the phone.
    1. Disassembling Nokia 6236i Display, Battery: step 1, image 1 of 2 Disassembling Nokia 6236i Display, Battery: step 1, image 2 of 2
      • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
      • Lift the battery case off of the phone.
      Ask FixBot
    2. Disassembling Nokia 6236i Display: step 2, image 1 of 3 Disassembling Nokia 6236i Display: step 2, image 2 of 3 Disassembling Nokia 6236i Display: step 2, image 3 of 3
      • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
      • The battery should lift out with minimal resistance.
      Ask FixBot
    1. Disassembling Nokia 6236i Display, Front Casing: step 3, image 1 of 3 Disassembling Nokia 6236i Display, Front Casing: step 3, image 2 of 3 Disassembling Nokia 6236i Display, Front Casing: step 3, image 3 of 3
      • Insert a spudger into the indention on the bottom right side of the device.
      • Slide the spudger upward to a second indention at the top of the phone.
      • The front casing will detach from the phone.
      Ask FixBot
    1. Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: step 4, image 1 of 3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: step 4, image 2 of 3 Disassembling Nokia 6236i Display, Disassembling Nokia 6236i Display: step 4, image 3 of 3
      • Use the flathead screwdriver to remove four screws on the upper half of the phone.
      • Lift the LCD up and off.
      Ask FixBot
2 other people completed this guide.
Author
with
Erik Lindahl
63 Reputation
4 Guides authored
Cal Poly, Team 10-46, Garner Spring 2010 Member of Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 77
All Time: 2,281
