Disassembling Nokia 6086 Top Front Cover
Views: 2.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
20
Past 30 Days:
101
All Time:
2,902
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is a step by step process to remove the top cover of the phone. It is the preliminary step, in order to gain access into the upper section of the phone.
Tools
    1. Disassembling Nokia 6086 Top Front Cover, Battery: step 1, image 1 of 1
      • Turn off the phone.
      • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
      • Position the phone so that the back side is in view.
      Ask FixBot
    2. Disassembling Nokia 6086 Top Front Cover: step 2, image 1 of 3 Disassembling Nokia 6086 Top Front Cover: step 2, image 2 of 3 Disassembling Nokia 6086 Top Front Cover: step 2, image 3 of 3
      • Remove the back battery cover.
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      Ask FixBot
    3. Disassembling Nokia 6086 Top Front Cover: step 3, image 1 of 3 Disassembling Nokia 6086 Top Front Cover: step 3, image 2 of 3 Disassembling Nokia 6086 Top Front Cover: step 3, image 3 of 3
      • Insert the iPod opening tool between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • The battery lifts out of the phone fast and easily.
      • Carefully lift the battery out of the phone.
      Ask FixBot
    1. Disassembling Nokia 6086 Top Front Cover, Top Front Cover: step 4, image 1 of 1
      • Close the phone.
      • Face the front cover forward.
      Ask FixBot
    2. Disassembling Nokia 6086 Top Front Cover: step 5, image 1 of 2 Disassembling Nokia 6086 Top Front Cover: step 5, image 2 of 2
      • Locate the 4.5 mm notch at the top of the phone.
      • Place the iPod opening tool into the opening.
      • Slightly prop up the top section by lifting the tool.
      Ask FixBot
    3. Disassembling Nokia 6086 Top Front Cover: step 6, image 1 of 3 Disassembling Nokia 6086 Top Front Cover: step 6, image 2 of 3 Disassembling Nokia 6086 Top Front Cover: step 6, image 3 of 3
      • Wedge the iPod opening tool between the top cover and the phone.
      • Gently lift the top cover away from the phone using the iPod opening tool.
      • This unlatches each hook that connects the top cover to the phone.
      • Repeat for both the left and the right sides of the phone.
      • Place the top cover aside once the top cover is completely disconnected from the phone.
      Ask FixBot
Andrea
70 Reputation
5 Guides authored
Cal Poly, Team 26-30, Regan Spring 2010 Member of Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 101
All Time: 2,902
