Up to 20% off select tools
Disassembling Nokia 3560 Vibrator
Views: 1.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
22
All Time:
1,864
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the vibrator from the Nokia 3560.
    1. Disassembling Nokia 3560 Vibrator, Back Cover: step 1, image 1 of 2 Disassembling Nokia 3560 Vibrator, Back Cover: step 1, image 2 of 2
      • Press down on the release latch on the bottom of the cover.
      • Once the latch is released, lift the cover from the phone.
      Ask FixBot
    1. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Keypad: step 2, image 1 of 1
      • Lift the front case off of the phone body.
      Ask FixBot
    2. Disassembling Nokia 3560 Vibrator: step 3, image 1 of 2 Disassembling Nokia 3560 Vibrator: step 3, image 2 of 2
      • Lift the keypad off of the phone.
      Ask FixBot
    1. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 LCD Display: step 4, image 1 of 1
      • The screen is held to the body by six screws.
      Ask FixBot
    2. Disassembling Nokia 3560 Vibrator: step 5, image 1 of 1
      • Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
      Ask FixBot
    3. Disassembling Nokia 3560 Vibrator: step 6, image 1 of 2 Disassembling Nokia 3560 Vibrator: step 6, image 2 of 2
      • Insert a flat screwdriver between the black body and plastic layer.
      Ask FixBot
    4. Disassembling Nokia 3560 Vibrator: step 7, image 1 of 1
      • Pry the layers apart. The LCD and plastic layer will lift out as one piece.
      Ask FixBot
    1. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Logic Board: step 8, image 1 of 1
      • With the screws removed, the logic board can then be lifted out of the body by hand.
      Ask FixBot
    1. Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: step 9, image 1 of 2 Disassembling Nokia 3560 Vibrator, Disassembling Nokia 3560 Vibrator: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • The orange piece is the vibrator.
      • It is not fastened by any means.
      • Remove with tweezers.
      Ask FixBot
Author
with
Sam Ryan
37 Reputation
8 Guides authored
Cal Poly, Team 30-39, Garner Spring 2010 Member of Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 1,864
