Up to 20% off select tools
Disassembling Nokia 3560 Battery
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
22
All Time:
1,862
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the battery from the Nokia 3560.
    1. Disassembling Nokia 3560 Battery, Back Cover: step 1, image 1 of 2 Disassembling Nokia 3560 Battery, Back Cover: step 1, image 2 of 2
      • Press down on the release latch on the bottom of the cover.
      • Once the latch is released, lift the cover from the phone.
      Ask FixBot
    1. Disassembling Nokia 3560 Battery, Battery: step 2, image 1 of 2 Disassembling Nokia 3560 Battery, Battery: step 2, image 2 of 2
      • Insert flat screwdriver or other flat object between battery case and housing.
      • Lift the battery from the housing.
      Ask FixBot
Author
with
Sam Ryan
37 Reputation
8 Guides authored
Cal Poly, Team 30-39, Garner Spring 2010 Member of Cal Poly, Team 30-39, Garner Spring 2010
CPSU-GARNER-S10S30G39
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 1,862
