Up to 20% off select tools
Disassembling Nokia 3395 Logic Board
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
79
All Time:
2,592
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
We will now remove the logic board from the phone.
    1. Disassembling Nokia 3395 Logic Board, Back Case: step 1, image 1 of 3 Disassembling Nokia 3395 Logic Board, Back Case: step 1, image 2 of 3 Disassembling Nokia 3395 Logic Board, Back Case: step 1, image 3 of 3
      • Turn the phone off.
      • Hold the phone, and gently press the white button located at the bottom of the phone.
      • While pressing the button, slide the back plate upwards, opening the plate.
      Ask FixBot
    1. Disassembling Nokia 3395 Logic Board, Battery: step 2, image 1 of 2 Disassembling Nokia 3395 Logic Board, Battery: step 2, image 2 of 2
      • Locate grey buttons beneath battery (shown).
      • Spread buttons simultaneously away from each other and the battery will pop out.
      • Remove battery from phone.
      Ask FixBot
    1. Disassembling Nokia 3395 Logic Board, Front Case: step 3, image 1 of 2 Disassembling Nokia 3395 Logic Board, Front Case: step 3, image 2 of 2
      • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
      • Flip over the device, and pry the faceplate away.
      Ask FixBot
    1. Disassembling Nokia 3395 Logic Board, Screen: step 4, image 1 of 2 Disassembling Nokia 3395 Logic Board, Screen: step 4, image 2 of 2
      • Remove six T6 screws.
      Ask FixBot
    2. Disassembling Nokia 3395 Logic Board: step 5, image 1 of 2 Disassembling Nokia 3395 Logic Board: step 5, image 2 of 2
      • Insert spudger between screen assembly and phone body.
      • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
      Ask FixBot
    1. Disassembling Nokia 3395 Logic Board, Logic Board: step 6, image 1 of 2 Disassembling Nokia 3395 Logic Board, Logic Board: step 6, image 2 of 2
      • Remove logic board as shown.
      Ask FixBot
3 other people completed this guide.
Author
with
Nico Lee
83 Reputation
6 Guides authored
Cal Poly, Team 30-41, Garner Spring 2010 Member of Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 79
All Time: 2,592
