Up to 20% off select tools
Disassembling Nokia 3395 Inner Components
Views: 3.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
87
All Time:
3,717
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
We will now disassemble the guts of the phone, including the SIM card reader, vibrating unit, power toggle button, audio speaker, power assembly/microphone, and the battery connector.
    1. Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 1 of 3 Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 2 of 3 Disassembling Nokia 3395 Inner Components, Back Case: step 1, image 3 of 3
      • Turn the phone off.
      • Hold the phone, and gently press the white button located at the bottom of the phone.
      • While pressing the button, slide the back plate upwards, opening the plate.
      Ask FixBot
    1. Disassembling Nokia 3395 Inner Components, Battery: step 2, image 1 of 2 Disassembling Nokia 3395 Inner Components, Battery: step 2, image 2 of 2
      • Locate grey buttons beneath battery (shown).
      • Spread buttons simultaneously away from each other and the battery will pop out.
      • Remove battery from phone.
      Ask FixBot
    1. Disassembling Nokia 3395 Inner Components, Front Case: step 3, image 1 of 2 Disassembling Nokia 3395 Inner Components, Front Case: step 3, image 2 of 2
      • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
      • Flip over the device, and pry the faceplate away.
      Ask FixBot
    1. Disassembling Nokia 3395 Inner Components, Screen: step 4, image 1 of 2 Disassembling Nokia 3395 Inner Components, Screen: step 4, image 2 of 2
      • Remove six T6 screws.
      Ask FixBot
    2. Disassembling Nokia 3395 Inner Components: step 5, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 5, image 2 of 2
      • Insert spudger between screen assembly and phone body.
      • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
      Ask FixBot
    1. Disassembling Nokia 3395 Inner Components, Logic Board: step 6, image 1 of 2 Disassembling Nokia 3395 Inner Components, Logic Board: step 6, image 2 of 2
      • Remove logic board as shown.
      Ask FixBot
    1. Disassembling Nokia 3395 Inner Components, Inner Components: step 7, image 1 of 1
      • Use the following legend to locate each component:
      • Microphone/power assembly.
      • Vibrating unit.
      • SIM card reader.
      • Audio speaker.
      • Power toggle button.
      • Battery connector.
      Ask FixBot
    2. Disassembling Nokia 3395 Inner Components: step 8, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 8, image 2 of 2
      • Insert spudger between power assembly/micro-phone and phone body.
      • Pry as shown and remove the power assembly/microphone.
      Ask FixBot
    3. Disassembling Nokia 3395 Inner Components: step 9, image 1 of 1
      • Once located, the following components are easily removed by pulling them out with your hand.
      • Vibrating unit.
      • SIM card reader.
      • Audio speaker.
      Ask FixBot
    4. Disassembling Nokia 3395 Inner Components: step 10, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 10, image 2 of 2
      • Audio speaker.
      Ask FixBot
    5. Disassembling Nokia 3395 Inner Components: step 11, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 11, image 2 of 2
      • SIM card reader.
      Ask FixBot
    6. Disassembling Nokia 3395 Inner Components: step 12, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 12, image 2 of 2
      • Vibrating unit.
      Ask FixBot
    7. Disassembling Nokia 3395 Inner Components: step 13, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 13, image 2 of 2
      Ask FixBot
    8. Disassembling Nokia 3395 Inner Components: step 14, image 1 of 2 Disassembling Nokia 3395 Inner Components: step 14, image 2 of 2
      Ask FixBot
Author
with
Nico Lee
83 Reputation
6 Guides authored
Cal Poly, Team 30-41, Garner Spring 2010 Member of Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 87
All Time: 3,717
