Up to 20% off select tools
Disassembling Nokia 3100b Speaker
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
94
All Time:
1,929
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide shows you how to access the speaker of your phone, the component which produces sound.
    1. Disassembling Nokia 3100b Speaker, Battery: step 1, image 1 of 1
      • Make sure your phone is turned off.
      Ask FixBot
    2. Disassembling Nokia 3100b Speaker: step 2, image 1 of 1
      • Press the button on the back of the phone and slide the back panel off.
      • Remove the battery by pulling it from the phone.
      Ask FixBot
    1. Disassembling Nokia 3100b Speaker, SIM Card: step 3, image 1 of 1
      • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
      Ask FixBot
    2. Disassembling Nokia 3100b Speaker: step 4, image 1 of 1
      • Retrieve your SIM card.
      Ask FixBot
    1. Disassembling Nokia 3100b Speaker, Screen: step 5, image 1 of 1
      • Separate the front cover from the main body of the phone.
      Ask FixBot
    2. Disassembling Nokia 3100b Speaker: step 6, image 1 of 1
      • Remove the six screws along the edges of the phone.
      Ask FixBot
    3. Disassembling Nokia 3100b Speaker: step 7, image 1 of 1
      • Pull the screen assembly from the base of the phone.
      Ask FixBot
    4. Disassembling Nokia 3100b Speaker: step 8, image 1 of 1
      • Carefully lift the keypad portion of the screen assembly from the circuit board.
      Ask FixBot
    5. Disassembling Nokia 3100b Speaker: step 9, image 1 of 1
      • Separate the screen from the circuit board.
      • Reconnect the ports during reassembly or the screen will not function properly.
      • Remember to reconnect the screen to the circuit board when reassembling!
      Ask FixBot
    6. Disassembling Nokia 3100b Speaker: step 10, image 1 of 1
      • Gently push down on the screen to pop it off of the assembly.
      Ask FixBot
    7. Disassembling Nokia 3100b Speaker: step 11, image 1 of 1
      • When the screen falls out the assembly, two white tabs will fall out with it.
      • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
      Ask FixBot
    1. Disassembling Nokia 3100b Speaker, Speaker: step 12, image 1 of 1
      • Set the screen and the tabs aside.
      Ask FixBot
    2. Disassembling Nokia 3100b Speaker: step 13, image 1 of 1
      • You can now access the speaker.
      • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
      Ask FixBot
    3. Disassembling Nokia 3100b Speaker: step 14, image 1 of 1
      • Remove the speaker from the assembly.
      Ask FixBot
Author
with
Sterling Fuentes
139 Reputation
8 Guides authored
Cal Poly, Team 29-64, Johann Spring 2010 Member of Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 94
All Time: 1,929
