Up to 20% off select tools
Disassembling Nokia 2366i Front Cover
Views: 1.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
85
All Time:
1,889
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide shows you how to remove the front cover of the phone so that you can access the internal components found there.
    1. Disassembling Nokia 2366i Front Cover, Battery: step 1, image 1 of 2 Disassembling Nokia 2366i Front Cover, Battery: step 1, image 2 of 2
      • Turn off the phone.
      • Position the phone so that the back side is in view.
      Ask FixBot
    2. Disassembling Nokia 2366i Front Cover: step 2, image 1 of 1
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
      Ask FixBot
    3. Disassembling Nokia 2366i Front Cover: step 3, image 1 of 3 Disassembling Nokia 2366i Front Cover: step 3, image 2 of 3 Disassembling Nokia 2366i Front Cover: step 3, image 3 of 3
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
      Ask FixBot
    1. Disassembling Nokia 2366i Front Cover, Front Cover: step 4, image 1 of 1
      • Keep the phone closed.
      • Hold the phones sideways with the front cover of the phone facing up.
      Ask FixBot
    2. Disassembling Nokia 2366i Front Cover: step 5, image 1 of 2 Disassembling Nokia 2366i Front Cover: step 5, image 2 of 2
      • Find the slight crease on the side that divides the display assembly in half.
      • Slowly wedge the spudger into the crease.
      • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
      Ask FixBot
    3. Disassembling Nokia 2366i Front Cover: step 6, image 1 of 2 Disassembling Nokia 2366i Front Cover: step 6, image 2 of 2
      • Run the spudger all along the crease while lifting up.
      • Separate the front cover from the front base.
      Ask FixBot
Author
with
Kristen
193 Reputation
1 Guide authored
Cal Poly, Team 1-14, Amido Winter 2011 Member of Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 85
All Time: 1,889
