Up to 20% off select tools
Disassembling Nokia 1100b RH-36
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
101
All Time:
3,263
Comments: 1
1 comment on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
How to disassemble the inside of your Nokia 1100b RH-36 to access the inner components.
    1. Disassembling Nokia 1100b RH-36, Battery Cover: step 1, image 1 of 2 Disassembling Nokia 1100b RH-36, Battery Cover: step 1, image 2 of 2
      • Flip the phone over so that the screen faces down.
      • Press the gray button on the battery cover and slide it down off the back of the phone.
      Ask FixBot
    2. Disassembling Nokia 1100b RH-36, Battery: step 2, image 1 of 1
      • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
      • Gently pry the battery out of the phone.
      Ask FixBot
    1. Disassembling Nokia 1100b RH-36, Front Cover: step 3, image 1 of 2 Disassembling Nokia 1100b RH-36, Front Cover: step 3, image 2 of 2
      • Firmly grip the back of the casing.
      • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
      • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
      Ask FixBot
    1. Disassembling Nokia 1100b RH-36, Inner Casing: step 4, image 1 of 2 Disassembling Nokia 1100b RH-36, Inner Casing: step 4, image 2 of 2
      • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
      • Remove the metal frame holding the screen and speaker.
      Ask FixBot
7 other people completed this guide.
Author
with
JSwan
838 Reputation
6 Guides authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 101
All Time: 3,263
