Up to 20% off select tools
Disassembling Nintendo 64 Cartridge
Views: 66K
View statistics:
Past 24 Hours:
11
Past 7 Days:
62
Past 30 Days:
302
All Time:
65,786
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 30
30 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
When games have been in storage or used for years on end, they need to get a good dose of TLC. In extreme cases you need to crack them open to get everything. It can be tense opening up a loved game in the fear that you'll destroy it.
Alternatively, you can open up a game no one liked and make it into an innocuous enclosure for something else.
    1. Disassembling Nintendo 64 Cartridge, Cartridge: step 1, image 1 of 2 Disassembling Nintendo 64 Cartridge, Cartridge: step 1, image 2 of 2
      • First flip your game over and you'll see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
      • Take the screws out and peel the case off starting from the top taking care not to force it due to the tabs at the bottom of the cartridge. Outlined in Red
      • The two halves of the case should come apart easily.
      Ask FixBot
    2. Disassembling Nintendo 64 Cartridge: step 2, image 1 of 3 Disassembling Nintendo 64 Cartridge: step 2, image 2 of 3 Disassembling Nintendo 64 Cartridge: step 2, image 3 of 3
      • On the inside of the front plastic casing the game board and metal shielding are attached with two Phillips head screws. Unscrew them to remove the shielding and access the game board.
      • The top of the metal shielding held on with pressure tabs. Be sure to press down firmly when reassembling.
      • With the shielding off, the main circuit board and pins can be seen.
      Ask FixBot
    3. Disassembling Nintendo 64 Cartridge: step 3, image 1 of 3 Disassembling Nintendo 64 Cartridge: step 3, image 2 of 3 Disassembling Nintendo 64 Cartridge: step 3, image 3 of 3
      • The only thing holding in the board is the plastic shield on the bottom of the cartridge. No screws are holding it in and is easily removed.
      • Now you can fully take out the cartridge board from the casing.
      • Here you can fully clean the pin set and inspect for damage to the circuit board.
      • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
      Ask FixBot
    4. Disassembling Nintendo 64 Cartridge: step 4, image 1 of 2 Disassembling Nintendo 64 Cartridge: step 4, image 2 of 2
      • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture of isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind).
      • While reassembling the cartridge, remember to put the lower plastic shielding underneath the two pins on the outer casing. There are two like this on both sides.
      Ask FixBot
To reassemble the cartridge, follow these instructions in reverse order.
29 other people completed this guide.
Author
with
BWest
3,468 Reputation
2 Guides authored
OPEN Member of OPEN
Community
90 Members
120 Guides authored
1 Guide Comment
Super surprised when I realized the ifixit kit has a gamebit.
Andrew - Reply Share
Past 24 Hours: 11
Past 7 Days: 62
Past 30 Days: 302
All Time: 65,786
