Disassembling Nikon Coolpix 5600 Front of camera
    1. Disassembling Nikon Coolpix 5600 Front of camera, Remove front of camera: step 1, image 1 of 2 Disassembling Nikon Coolpix 5600 Front of camera, Remove front of camera: step 1, image 2 of 2
      • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
      Ask FixBot
    2. Disassembling Nikon Coolpix 5600 Front of camera: step 2, image 1 of 2 Disassembling Nikon Coolpix 5600 Front of camera: step 2, image 2 of 2
      • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
      Ask FixBot
    3. Disassembling Nikon Coolpix 5600 Front of camera: step 3, image 1 of 1
      • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
      Ask FixBot
    4. Disassembling Nikon Coolpix 5600 Front of camera: step 4, image 1 of 1
      • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
      Ask FixBot
To reassemble your device, follow these instructions in order.
3 other people completed this guide.
Crista Riedy
421 Reputation
3 Guides authored
Ohio State, Team 1-2, Buehl Spring 2013 Member of Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 23
All Time: 853
