Up to 20% off select tools
Disassembling Nikon Coolpix 5600 Flash Unit
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
81
All Time:
1,512
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: step 1, image 1 of 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: step 1, image 2 of 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: step 1, image 3 of 3
      • Remove the screws from the bottom, right, and left side of camera.
      Ask FixBot
    2. Disassembling Nikon Coolpix 5600 Flash Unit, Remove back: step 2, image 1 of 1
      • Remove the back of the camera, this may require force.
      Ask FixBot
    1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Metal Bracket: step 3, image 1 of 1
      • Unscrew the right metal bracket of the viewing lens
      Ask FixBot
    1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove front of camera: step 4, image 1 of 2 Disassembling Nikon Coolpix 5600 Flash Unit, Remove front of camera: step 4, image 2 of 2
      • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
      Ask FixBot
    2. Disassembling Nikon Coolpix 5600 Flash Unit: step 5, image 1 of 2 Disassembling Nikon Coolpix 5600 Flash Unit: step 5, image 2 of 2
      • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
      Ask FixBot
    3. Disassembling Nikon Coolpix 5600 Flash Unit: step 6, image 1 of 1
      • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
      Ask FixBot
    4. Disassembling Nikon Coolpix 5600 Flash Unit: step 7, image 1 of 1
      • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
      Ask FixBot
    1. Disassembling Nikon Coolpix 5600 Flash Unit, Disassembling Nikon Coolpix 5600 Flash Unit: step 8, image 1 of 1
      • Unscrew the grey plastic around the screen
      Ask FixBot
    2. Disassembling Nikon Coolpix 5600 Flash Unit: step 9, image 1 of 1
      • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
      Ask FixBot
    3. Disassembling Nikon Coolpix 5600 Flash Unit: step 10, image 1 of 1
      • Maneuver to detach the flash bulb.
      Ask FixBot
    4. Disassembling Nikon Coolpix 5600 Flash Unit: step 11, image 1 of 1
      • Unscrew the metal bracket under the lens
      Ask FixBot
    5. Disassembling Nikon Coolpix 5600 Flash Unit: step 12, image 1 of 1
      • Slide the plastic bracket through the metal bracket.
      Ask FixBot
      • Remove the orange cable from the motherboard.
      Ask FixBot
    6. Disassembling Nikon Coolpix 5600 Flash Unit: step 14, image 1 of 1
      • Pull the black tape off.
      Ask FixBot
    7. Disassembling Nikon Coolpix 5600 Flash Unit: step 15, image 1 of 1
      • Unscrew the two screws underneath.
      Ask FixBot
      • Remove lens
      Ask FixBot
Author
with
Crista Riedy
421 Reputation
3 Guides authored
Ohio State, Team 1-2, Buehl Spring 2013 Member of Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 81
All Time: 1,512
