Up to 20% off select tools
Disassembling Netatmo Outdoor Camera Main Unit
Views: 2.1K
View statistics:
Past 24 Hours:
12
Past 7 Days:
75
Past 30 Days:
282
All Time:
2,101
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
My camera stopped working, and technical support told me that there was a fault with the optical sensor, and it couldn't be repaired.
I thought, "I wonder why it failed?", and then started exploring the inside of this security camera. After some adventuring I discovered moisture had eaten away connections on the camera ribbon cable and that needed repair.
The cause of the problem was a poor seal of hot-glue and silicon lube. The failure happened out of warranty, but was really a manufacturer defect.
This guide explains how to take a Netatmo Presence Outdoor Camera to pieces and access the electronics.
    1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: step 1, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: step 1, image 2 of 2
      • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
      • The panel will lift up and can be removed.
      Ask FixBot
    2. Disassembling Netatmo Outdoor Camera Main Unit: step 2, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 2, image 2 of 2
      • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
      • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
      • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
      Ask FixBot
    3. Disassembling Netatmo Outdoor Camera Main Unit: step 3, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 3, image 2 of 2
      • Remove the six 2.5mm hex screws using a long Allen key.
      • One screw has an earthing ring wire. Don't forget this when reassembling.
      Ask FixBot
    4. Disassembling Netatmo Outdoor Camera Main Unit: step 4, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 4, image 2 of 2
      • Separate the two pieces by pulling slightly on the lower module.
      • Pull the metal housing forward.
      • Pushing the light from the inside can help in removing the shell.
      Ask FixBot
    5. Disassembling Netatmo Outdoor Camera Main Unit: step 5, image 1 of 1
      • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
      Ask FixBot
    6. Disassembling Netatmo Outdoor Camera Main Unit: step 6, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 6, image 2 of 2
      • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
      • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
      • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
      Ask FixBot
Author
with
The Virtual Traveller
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 75
Past 30 Days: 282
All Time: 2,101
